Footer not publishing
Hello all,
Just trying to get one of these flexible layouts working.
Could you please take a look at:
http://www.trevreav.co.uk/TAMARWEB/aboutthetamarott.html
If you then take a look at any of the other unfinished links you’ll notice that there is a green strip of footer containing the address. For some reason it refuses to publish on this page.
Once again, any suggestions greatly appreciated.
The “map7” footer is definately missing from the page code…if that’s the one you are looking for. Try forcing a republish.
Thanks Chukamuck,
I’ve tried that and it still didn’t work.
Then perhaps it’s off the bounderies of the page. In layout mode, at the bottom of the page in the left or right corner, do you see a small square with an X through it? If you do, try resizing the box containing your footer.
No, it exists there in the Freeway layout, the same as on the master
and all pages based on it. No little crosses or anything.
That’s me done for today, so please don’t think me rude if I don’t
answer until tomorrow. Been a bit of a day…
Thanks for the suggestions.
…the same as on the master and all pages based on it.
Ah. The master page link maybe broken. Try reapplying the master to this particular page.
Yes, that was it, thanks. But reapplying the master page has deleted
the main content of the page.
Ho hum, not a big job to redo it, just annoying.
Thanks Chckamuck, I’ll remember that one.
One thing I’ve learned over the years: when reapplying the Master,
before you do, select and copy everything on the page that isn’t part
of the Master then, when you’ve reapplied you can past it back in.
best wishes,
Paul Bradforth
http://www.paulbradforth.com
