I’ve created a form using a table and insereted my text fields and text area then applied the FES action and styled fields as required.
My issue is when inputting data into the fields the cursor appears in the middle of the form fields rather than at the start (top), even in the text area field that 100px deep?? Why is this?
Also is there a way to style the text inside the text area field to return once each line is filled… currently it continues to run out of the fields visible type area… annoying???
