Hi
I have set up this form using Freeway’s ‘Send Form’ action (I have tried other methods as well), and although I am sent to the Success page the email never arrives. I have spoke to my ISP on this and he advised me that the PHP script should say // Server $allowsotherdomains = FALSE. So I changed this using a text editor - can this be done in Freeway or do I have to do this in a script editor everytime I update the site.
Unless you go and hack the actual Send Form action (which I don’t recommend), you will need to manually adjust the code each and every time you upload.
Hi
It seems that this site has been put on a newer server with higher security and that is causing all kinds of problems with the form. i.e. it won’t send using the applicants email, it has to be an email address connected to the server i.e. mine.
Any thoughts on how to over come this?
