What about posting the content of the contact_us-go.php file
<?php
$notindomain_errorpage = "notindomain.html";
$server_errorpage = "serverfailure.html";
$invalidaddress_errorpage = "fail.html";
$successpage = "pass.html";
$recipient="email@hidden";
$subject="Web site feedback";
// Set the server variables for older (PHP4,3 etc) systems
if (!isset($_SERVER)){
$_POST = &$HTTP_POST_VARS;
$_SERVER = &$HTTP_SERVER_VARS;
$servername = $_SERVER['SERVER_NAME'];
if ($_SERVER['REQUEST_METHOD']=="POST") {
if (strpos($_SERVER['HTTP_REFERER'], $_SERVER['HTTP_HOST'])>7 || !strpos($_SERVER['HTTP_REFERER'], $_SERVER['HTTP_HOST'])) {
header( "Location: ".$notindomain_errorpage );
exit;
} else {
$msg="The following information was submitted from a form on ".$servername.":\n\n";
foreach($_POST as $key => $val) {
//filter out any form items called send or reset
//image based submit and reset buttons will be in the format
// send_x: 13
// send_y: 10
$myKeySlice = substr("$key",0,4);
if ($myKeySlice != "send" && $myKeySlice != "rese"){
if ($key == "subject" || $key == "email" || $key == "name"){
//Prevent injection attacks by stripping tags and newlines from the data
//Do this only on data that makes it into the e-mail header as newlines in a message body should still be valid
$key = strip_tags($key);
$val = strip_tags($val);
if (eregi("\r",$key) || eregi("\n",$key)){
exit;
if (eregi("\r",$val) || eregi("\n",$val)){
exit;
//replace any underscores in the input names (PHP puts these in!) with spaces
$key = str_replace("_"," ",$key);
//if the form item is called "subject" then set this as the subject line of the mail
if ($key == "subject"){
$subject=$val;
} else {
if (is_array($val)){
$msg.="Item: $key\n";
foreach($val as $v)
$msg.="ÊÊÊ$v\n";
} else {
$msg.="$key: $val\n";
//set up the default headers
$headers = "";
//get the senders name (if specified)
if ($_POST["name"]) {
$name = $_POST["name"];
} else {
$name = "";
//get the senders email address (if specified)
if (isset($_POST["email"])) {
$email = $_POST["email"];
if (!preg_match('/^[a-zA-Z0-9_\.-]+@[a-zA-Z0-9-\.]+\.[a-zA-Z]+(\.[a-zA-Z]+)?$/', $email)){
header( "Location: ".$invalidaddress_errorpage );
exit;
} else {
//the email is missing!
//strip the domain from the address
//www.domain.com -> domain.com
if (substr($servername,0,4) == "www."){
$theaddress = substr($theaddress,4);
$email = "noreply@".$theaddress;
$msg.="\n\n------------------------------------------------------------------";
$msg.="\nPLEASE NOTE: This is a message from the ".$servername." web site";
$msg.="\nand has been sent from a machine and not a person.";
$msg.="\nPlease do not reply to this e-mail as it will bounce.";
$msg.="\n------------------------------------------------------------------";
$headers .= "From: $name <$email>\r\n";
//add the correct headers for plain text
//see: http://www.webmasterworld.com/php/3949990.htm
$headers .= "MIME-Version: 1.0\n";
$headers .= "Content-type: text/plain; charset=\"ISO-8859-1\"\n";
$headers .= "Content-transfer-encoding: 7bit\n";
$headers .= "Reply-To: $email\r\n"."Return-Path: $email";
error_reporting(0);
if (mail($recipient, $subject, $msg, $headers)){//
header( "Location: ".$successpage );
} else {
header( "Location: ".$server_errorpage );
} else {
Dave Ive gotta go offline now ill be back in a few hours -
Thanks for all the help
J
What version of the action are you using?
Current is 2.3.7
The good news is that I took your contact_us-go.php page, put it on my server and submitted a form to it and it works!
Bad news is - I don’t know what your problem is but it may be server related.
Great thanks - according to Fatcow its not a server thing - but they would say that - Anyway thanks again ill wait to see what Softpress has to offer.
J
