Per Walt’s request I am reposting this suggestion as a new thread.
I think what might be helpful with organizing the threads would be to have a hierachical view showing only the first line of each response and responder name and date below the original post. Clicking on a response would expose the whole post with “accordian” effect?
Oh, okay. I posted this in the other thread but I’ll report it here.
One suggestion that I have for the new forum is one thing we tried to get people to do in the phpBB forum, which was to put their OS, hardware, and FW version in their sig. At the very least, I think it would be a useful aspect of the People profiles to be able to choose FW version and OS so that others can see. It would be even more helpful to have that as part of each post, perhaps as smaller gray text at the bottom or something similar.
The only problem I can see with this is that people (me) continually
forget to update their profiles.
One suggestion … would be a useful aspect of the People profiles to be able to choose FW version and OS so that others can see. It would be even more helpful to have that as part of each post, perhaps as smaller gray text at the bottom or something similar.
Although I never used the signature feature before because they have mostly been used for sillyness, I agree that having a fixed line under a response with hardware/software specs is good idea.
Also, when quoting text there is a link shown in the reply box when typing, but it does not show after being posted. In this particular response it show “http://freewaytalk.net/person/options”.
Hmmm that is very odd behavior Walt. The response I just posted is all quoted when in reality my response at the bottom was cut off. Some of the response is missing.
The footer snipper struck! I have to figure out why the footer is not being snipped in the Quote: button code, as it should be.
The second line of your message matched the filter for being part of the footer, and so it was stripped from the Web view.
It’s not gone forever, it’s still in the database, but I need to come up with a smarter filter that won’t be so greedy.
It may be a good idea to reorganize the category buttons also as I am seeing Freeway related questions in Off Topic category. How about making sub category buttons under Freeway button?
On the subject of finding new posts, what if new posts were a different color in the thread before being read, then the normal color once they have been read?
That’s a really elegant suggestion. It won’t work on a message-by-message basis, though, because you view a thread at a time, not a message at a time. But it would work up at the forum level, since you view the messages at that level in a thread-by-thread manner.
It’s baaaack!
As to the reason why your first line of text was mashed in with the quote, it’s because there was a > character right before it. I have tried to force the text formatter to be less cranky about this sort of thing, but it’s really really hard to make a filter work for everything without having to compromise in some place or another.
Use double-returns to separate blocks of content from one another and you can’t go wrong!
I just tried doing a search for “page id” and basically it came back with over 10,000 posts. This is not a very useful search routine as it stands. Is there a trick involved to make it more useful?
Not yet. Finlay and I are working to add a world-class search engine
(Sphinx) to the system, but right now, we’re still mopping up the
flood from the transition.
At the moment, the search uses Porter Stemming and substring
matching, and does not use any boolean operators at all. When I get a
moment, I will upgrade it to a full-text index, but this afternoon,
it would be easier to google it:
useful?
