shouldn’t it be possible to set a frameset as master? the option is greyed out for me - (I’m in Express - does that make a difference? and I did not have sources assigned for all frames yet - would that affect anything?) - thanks - ROlf in MA
it was the only way I could think of to do this e-book - correct me if I’m wrong (I probably am), but I need the main ‘frame’ to scroll - it’s the main text of each chapter - but I also need the side and top links (parts, sections, chapter, appendix, footnote links) to ‘stay with’ the scrolling text - how do I do that without frames??
I guess you’re right - and I’d go for Pro if it could definitely do what I need it to do - but he’s firm on the graphic text — is there really no way to scroll a graphic item and keep side links alongside? look at this page, for example - why not keep the header, footer, and side links stationary, and scroll the conversation? (on the other hand, this layout would work OK for the book, and it’s pretty simple to shoot to the top or bottom…) - but while I’m at it, is there any way to write a thinner, more-rectangular scroll-bar? that Aqua thing is OK on the edge of the screen, but it looks pretty coarse in the middle of a frame - regards, thanks for the replies, - Rolf in MA, US
I don’t know, I think I can make this work in frames - don’t care about bookmarking or text searching, we just want people to be able to read the thing
(unrelated text, and the links aren’t active and the colors suck, but this is what I’m trying to do)(I think it’s good enough): http://frames.vagus.4u2bu.org/
You could have all your section headers, navigation etc. fixed while the central area with the readable graphic text can scroll - and no scroll bars or Frames.
You could also have all your sections, headers,navigation etc in HTML text and be nice and indexable by Google - and bookmarkable too.
I’ve been following this discussion out of interest in something possibly similar in what I want to do.
This solution, given the discussion that came before, is simply brilliant - or elegant in its simplicity as the chess players amongst us would say.
Thanks, David.
Martin
Signal Mountain, TN
On Mar 25, 2011, at 4:58 PM, DeltaDave wrote:
There is another option in Pro
It uses the position:fixed in window attribute
excellent! will that also keep the footers fixed? or will they be at the bottom of the scroll? I notice they are missing in your example - thanks again! - R
Did you want me to duplicate your entire site - or just show you what can be done?
But seriously - if you made the footer fixed as well then your ‘text’ would scroll behind it and would probably look odd. And probably cut off some text.
this is how Google Books does it - is this the same thing as Pro? and I DL’d the Pro Trial, but can’t find ‘position:fixed in window’ attribute - where is that? - thanks, - Rolf in MA
