Freeway Alternative – Pinegrow Web Designer
@ Walter
Could your ‘inlay’ CMS also be used in for example Blocs, Sparkle or CC’s
Responsive Site Designer as long as it can embed your code and the site
runs on a php server?
And it is restricted to text only?
Andries
2016-08-02 16:38 GMT+02:00 David Ledger email@hidden:
On 2 Aug 2016, at 00:58, JDW wrote:
I also don’t understand the appeal of WordPress either. If I want to
add content to my site, I just use Freeway. That would hold true of any
blog. Why use WordPress, especially when I see in my server Error Logs
daily that hackers from China, the USA, Russia, France, the UK, and the
Ukraine are daily searching for Wordpress files on my server they can
hack. It doesn’t make sense to me.
WordPress (and similar) really comes into its own when you have a large
number of information contributors and you either don’t want the task of
entering it all, or it’s not financially viable for you to be paid to enter
every extra bit of data. It’s also well known so there a lot of people who
can take it over when you are unable to manage it (we’re not all under
retirement age). It doesn’t make much sense (to me) for a company sales
site. It also doesn’t make much sense (to me) for a site where a unique
graphic design is important.
You can use it in anything that creates HTML. As long as you can add the data-element to the item you wish to edit, you are all done.
At this moment, Inlay does not manage images for you – you cannot upload and manage and resize those images directly in the Inlay interface. However, you are able to add and edit images within text elements in the Markdown or WYSIWYG editors. You will need to upload those images somewhere public, and get the complete URL to the image. For Markdown, you would place your cursor within the text where you want your image to appear, type the “alt text” and highlight it, then press the Image button, and paste the URL into the dialog. For the WYSIWYG editor, it’s very similar. The image has to already exist somewhere.
On Aug 2, 2016, at 10:53 AM, email@hidden wrote:
@ Walter
Andries
OK - now we know that a CMS is a server-side application!
All it requires is an editor, that can incorporate CMS specific code-snippets.
Pinegrow can - because it’s a code-editor! This is btw the reason, why Pinegrow even can handle projects - although it’s not “intended” for.
Any other " code stupid misunderstandings" out there to clarify?
Thanks Walter!
2016-08-02 19:16 GMT+02:00 Thomas Kimmich email@hidden:
code-snippets.
David, thank you for your two helpful replies. Regarding CMS, is that how you would categorize an off-site hosted FileMaker Pro database?
We host 2 databases with MacUSA because, quite frankly, they are the cheapest FileMaker host out there, and they’ve done a great job for us for the last few years:
http://www.macusa.net/FMP12.html
We just link to a login page hosted on their server for our dealers to login and access wiring data. To make changes, we just upload the updated FM database. It uses FM IWP, somewhat dated but much cheaper down the line than price categories the newest FM versions force you into.
I’m just trying to get my head around what defines a CMS. For if our FM database is defined as CMS, then how is our base website defined seeing we host it on a server in CA that doesn’t belong to us, and we are based in Japan?
Wow, you could get quite metaphysical trying to define a CMS, I guess. What you have going (your wiring data) is more along the lines of a “web app”, rather than a straightforward CMS. You allow user input to direct the output, following an algorithm defined in your database and its view layer. In a sense, that’s what a CMS is, but quite a bit more specialized for showing the content of a Web site, rather than wiring diagrams. If I recall correctly, you allow people to search and refine their choice by model, year, and make, and then you show the wiring diagrams that apply to that particular vehicle. That’s something you would struggle to build out of a traditional CMS, since those are more along the lines of “show me a navigation panel for this section”, then “choose a page from the list” and “show me the page I asked for”. It’s less complex by far.
MacUSA.net FileMaker 12 Hosting
Thank you, Walter!
–J. Wages
Today I was finally able to spend some time with Pinegrow Pro. A client gave me a url for a site that they wanted to update/revise with their unique marketing techniques and yet keep the same look and feel as the client’s original. PG was the perfect tool for this. Opening an html file from right off the web and removing/replacing DIV’s with different content including responsive videos and such was just really cool. It took me quite awhile because of the learning curve, but I can see where this will be an invaluable tool.
I think maybe someone else mentioned that you could visually design in something else and then open in PG and go to town under the hood adding extra bells and whistles that may not be included in a codeless program.
This was worth the investment.
FLUX is discounting its latest version 6 for a few dollars. WYSIWYG and
coding…
2016-08-04 4:54 GMT+02:00 Frank Bridges email@hidden:
But how is FLUX fundamentally different from Dreamweaver? Dreamweaver for years has offered something similar (which never pulled me away from Freeway, by the way). Here’s a short look at Flux:
To me, Pinegrow would seem to fill a need (for me), if and only if Freeway stopped working and for some reason I couldn’t get it to work, and I still haven’t chosen another web design app (say Blocs) in which to redesign my sites, so I would need to pull existing HTML files into Pinegrow to perform modest edits. But I, being a visual designer, really wouldn’t want to stay in Pinegrow simply because it is focus more on the code. The best solution for me, if I want to create a fully responsive site, would be to choose something like Sparkle or Blocs to have a rather easy means of creating responsive designs (something I never was able to accomplish in Freeway, because I lack the time, dedication and metal skills that other Freeway users have; namely, Thomas K. and Ernie S.).
–James Wages
@ James
For your demands I think Blocs is the tool.
2016-08-05 2:35 GMT+02:00 JDW email@hidden:
Flux V Web Design App for Mac: Review - YouTube
–James Wages
@ James
For your demands I think Blocs is the tool. Or CC’s Visual Site Designer
aka Foundation Framer but this one will need some more time to learn.
–James Wages
On 5 Aug 2016, 2:16 am, Andries Kuipers wrote:
@ James
2016-08-05 2:35 GMT+02:00 JDW :
–James Wages
Within the last week(s) you recommended:
  • Adobe Muse
  • Flux
  • Blocs
  • Sparkle
Furthermore you’re obviously a big fan of Coffee Cup stuff.
####This all is fine - nothing against (but for each is a special list available where you can share your wisdom much better than here).
###But this is the Pinegrow talk!
Within this talk, all you had to add is, that it isn’t able to manage and create projects which is proven wrong cause of the master-page concept ( Master Pages - Build your own blocks Part 6 - YouTube ).
You’re trying to upset some brave people giving it go. Some could have the impression that you’re a babbler. Trying to recommend James D. Wages to use Blocs is a daring step (if you would know him).
As previously said, Pinegrow isn’t an alternative to nothing - it’s an exceptional concept. It requires some basic knowledge - which isn’t too hard to achieve.
And with a little bit of the help of our wizzes here, it could be upset very “Freeway-like” (even above). It has Bootstrap, Bootstrap Blocks, Foundation, Materialize and even Angular.js ready to start.
Actions could be seen as pre-made blocks. All it requires is code-affine people doing code-affine work, allowing you to work from scratch.
Thomas, what is the “basic knowledge” that is required to use Pinegrow?
I watched your video and saw you easily import your existing site, then change text, all without using code or reading a manual. So again, what knowledge is required to use Pinegrow?
–James Wages
I’ve not used FileMaker beyond v6, but still use that for accounts. As a web interface to an FM database that interface could be considered an extreme web CMS because it’s seen as a database and its website aspect is usually overlooked. Using it as a website is something I hadn’t considered before. I gather there is now sql access to a FM database which I would hope could be accessed by php routines to populate web page items just like with MySQL. I wouldn’t know if the FM web presentation uses SQL/PHP or some private internal method. As long as you can design a FM layout that gives you the ‘web’ appearance you want it sounds like a really good way of doing a CMS website.
A possible definition of a CMS is that the data being shown is inserted programatically at display (serving) time, rather than being inserted via keyboard before upload.
In around 2010 I converted an FM database to MySQL by showing the whole thing as a huge single page website, capturing the source, and using TextWrangler global replace (via many intermediate versions) into SQL INSERT statements.
Jumping in here: I have used Pinegrow, and I can’t imagine there is any learning curve to opening an existing site and changing words. But if you open a blank page, the difference between it and Freeway is really striking.
If you’re familiar with Bootstrap and its conventions and available components, then the options of what you can drag to the page and start customizing (it’s really just like using Backdraft, in a way) will seem familiar enough. There are pre-built rows (horizontal slices of the page) with various popular layouts, like the “3 circular icons with a short product feature below each” module, or the “big-ass Carousel” module. If you see something you like in the stack of possible layout parts, and drag it to the screen, you can then start fiddling with it. The tools for this are not as straightforward or discoverable as I would like, but they are there. If you can organize your design thoughts around a 12-column grid (kinda like looking through a picket fence at your mental sketch) then I can imagine it being a very productive tool after an initial bit of head-scratching.
The primary benefit of this application is that you are building on top of a framework that gives you responsive for free. You can very easily build a layout in one breakpoint, without looking at the others, and get something workable at all breakpoints without thinking about it or click-click-dragging anything. The convenience and speed of this approach cannot be overstated.
Bootstrap makes it incredibly easy to build a “Bootstrap-looking” site. I can make something handsome in moments, using a text editor and a collected understanding of what the classnames are and how they have to be nested in order for the layout to work. Pinegrow makes it easy to get this part right. You pay for that ease with the *“80% problem”, unless your client likes that look, in which case you make bank and go home early.
Like any opinionated framework, Bootstrap makes it very difficult to go off the rails and do something unique. I’m not saying this is impossible – it’s very definitely not – but you have to know the rules in order to break them here. Contrast that with Freeway’s cheerful long toss of the rules into the middle distance, letting you do anything you want and writing whatever tortured HTML+CSS is necessary to support this ignorance whenever you press Publish. If a blank page fills you with inspiration, rather than dread, then the DTP approach (not present in Pinegrow as far as I can see) will be your best friend forever. If you prefer a set of guides, then the Bootstrap Pinegrow technique can give you a great starting point, at the expense of making it harder to make something that doesn’t look like every other Bootstrap site.
I’m not choosing sides here, mind you, because I have noticed my own designs becoming less ambitious since I learned the rules. But my newer pages are much more efficient and easier to use as templates, and that does matter for the kind of work I do.
*The last 20% of the job consumes 80% of the budget/time.
–James Wages
For myself, if a grid is the primary reason for considering Bootstrap or Foundation then Susy http://susy.oddbird.net/ is a much lighter, more flexible and far less intrusive alternative. Of course it requires Sass but that’s just the cherry on top as far as I’m concerned.
In some respects I can definitely see the appeal of Bootstrap and Foundation but they come too much overhead and yes, that ubiquitous Boot “look” for my taste. I never liked the sledgehammer approach. But that’s me, clearly I’m in the minority considering Bootstrap’s widespread use.
For better or worse Bootstrap (and to a lesser extent Foundation) knowledge is almost expected in the majority of the corporate jobs I see listed. I think a lot of companies simply don’t investigate their options, they pick what they think “everyone else” is using or because it’s the “buzzword of the month” and run with it.
If you want a grid without all that canned stuff then Susy is worth a look, plus you get Sass for free.
Office (Chicago): 312.212.3955
https://qreativ.space https://qreativ.space/
From my brief experience with Pinegrow I think it’s an interesting tool. I would consider using it for prototyping, especially if Bootstrap was a requirement.
Hi guys,
@James
I’ve allowed myself wrapping your question into a lil screencast:
I double Todd’s concerns about the “bloated” framework approach(es). As Walter already mentioned, a no-brainer though.
I’m currently working on my own lil basic starter kit. Pinegrow allows creating reusable snippets - so the “start from scratch” is less daunting and even if it sounds a bit arrogant:
My self-developed grid is still the best.
Some work to do - but web design is work - even a job.
Yeah, reusable code is a hugely efficient time-saver, be it Pinegrow or any proper text editor.
