On 23 Nov 2017, 1:35 am, JDW wrote:
Fascinating. The GUI is rather compelling, although it’s clear you still need a firm grasp of the code to get the most out of the strangely-named “Pinegrow.”
Hi JDW,
Sorry for the delay in responding.
As Thomas already pointed out, Pinegorw offers the proper corresponding table items in the library associated with whatever you are building your page with, plain HTML5, Bootstrap, Foundation, etc. You can use them, then associate your own custom CSS classes and media queries to create whatever type of responsive tables you desire. Or use one of the many existing 3rd party responsive table frameworks natively in Pinegrow also. The same goes for any type of search you wish to implement. A few items from the library coupled with the needed associated logic of your desired chosen search.
But as you hinted, you need a certain basic grasp of HTML, CSS, JS to fully leverage things. The Visual CSS Editor now in Pinegrow should help many concerning the CSS portion. With Pinegrow nothing is really off limits though. As Thomas mentioned it works with native source files and everything is exposed and accessible for creation and manipulation. If you wanted you could use a program like Blocs to get your general responsive page structure and overall content setup based upon Bootstrap. Then use Pinegrow to help with visually adding additional features you wish to implement that Blocs presently does not have, or you don’t feel comfortable or limited implementing via its HTML Bric, Page Settings, etc. Such a workflow may be easier for some than starting from scratch in Pinegrow, but easier than just doing edits via a text editor.
Of course no app will have every feature desired by every user. With an app like Pinegrow it gives open access to add, create and manipulate the things you need however, so you can add any desired feature yourself. It looks like Blocs will continue to gain more features and access for adding things also, in version 2.5 thru version 3. Perhaps by then you will also know more what the new Freeway rewrite will offer regarding workflow and features also?
Something to consider and keep in mind, you (or anyone) could learn a lot with and from Pinegrow during the same time spent waiting for other apps to add features. By learning further while you wait, you will only improve your overall abilities and understanding. That will help with any app you end up using, and the overall general process of creating websites.
PS: The Pinegrow name was derived from a love of pine trees. As odd as it might seem, the name aids in it standing out and not getting lost in a sea of app names that can be associated with non related things. Which easily occurs with many other app names, via simple google searches.
