Hi Mike,
… does Ecwid have the same sort of functions for orders, like Mals?
I tend to say yes - but what do you mean exactly? You can proceed a “Test-Shopping” on Ecwids Demo-Shop to see if it comes up to your expectations. And you can throw goods into your cart by drag’n drop.
Now how do you change styles in Ecwid …
Hmmmm - OK, this is a bit more complicated - nothing out of the box, cause all the styles are driven by a huge CSS within your backend. There are really a tons of different styles and you have to find out what style belongs to what position (and believe me, I still found out a few…).
First step would be to copy the default style, giving it a new name. Go through the styles and make some changes to see if it comes up to your desires.
To make work easier I copied the complete css-file and put it into a CSS-Editor called, yes … CSSEdit.
It is btw. an editor I’d like to see as implement within the Freeway-Surrounding for all of those that need to work closer to css editing (just a suggestion).
All in all it’s a question of study and try-outs but it is to achieve.
And I forgot to point out another possibility:
Assumed you’ve got only a few products to sell, you could just insert the “add-to-bag” button and make a free design within freeway. We discussed this somewhere else on the board, but my example was:
http://www.kimmich-dm.de/ecom/ecwid-tables.php
This is all done within the WebYep-Surrounding (RichText Elements) and another way down the road. You see: I did a lot of try-outs and that was the key to open the world of Ecwid. If I find the time I should build a bit more inspired example and wrap this in another screencast.
So this is why I felt in love with ecwid as actually to most exciting cart solution. For sure Mal’s or Roman are nice as well - but to me personally a bit antique both and for a long time not seen any wow-developpements.
But it needs to match your selling-needs as well. For Germany for example it’s actually more than hard to use, cause the ecwid tax-issues are not really match the german tax-law (but there is no solution out there that do anyway - except of the German Big 5 Paid One).
