Thanks Softpress! I downloaded the Pro 7 upgrade two hours ago and still haven’t sorted out the mess it has made to a navigation bar.
Hi Colin,
I’m sorry to hear that If you get in touch with our support team with a copy of your file they’ll be able to help out: support(at)softpress.com
It’s OK, thanks, Joe. That was just a frustrated sounding off! Upgrading anything always seems to create a set-back. Sometimes an expensive one such as when a new operating system wouldn’t support my scanner and that sort of thing! This was minor.
The simplest solution is a quick re-write of it using the new process which is already clearly so much easier than the previous one. Half done already.
Great!
