Freeway Pro is driving me mad!
For some reason a right floating box on one of my web pages was getting pushed into the left floating text box, but I couldn’t figure out why. I spent at least two hours trying to figure it out. About two minutes before I was getting ready to put my fist through my monitor I solved it.
Anyone want to try to guess what the problem was?
99% of occurred problems are sitting in front of screen?
It would be easier to guess your mother in law’s maiden name - at least from the information you have given us!
LOL, you’re too funny. And yeah, you’re right Dave. I was kinda out of it last night.
As it turns out it was an outside HTML container. It was set to Float Left instead of Float None, which was screwing up the alignment of the Right Floating Floating HML box within it.
I’m still getting used to all of this floating box stuff now that I’m using Inline Box layouts or whatever it’s called. :slight_smile:
Not sure I will ever get used to it!
I am waiting for wider browser support for Flexbox and then will try and wrap my head round it.
