I have just had the problem with the Link Verification not working, resulting in the error message. Following Keith’s advice I reset my ‘payments password’ from 8 characters to 6 characters and now everything seems to work. Strange!
Purchased and using Mal’s Ecoomerce Suite with Freeway Pro 5.3.2
I have been working for 6 hours trying to correct a “Link verification error”.
I made a form in Freeway with Mal’s Buy Form Setup action applied, the form contains a Mal’s Multiprice Select Action menu and a text field with Mal’s Quantity Field/Checkbox/Radio action applied and lastly, a simple submit button. That’s it.
When I preview the form in a browser, select something from the pop-up menu, enter a quantity in the text field, then hit the Submit button, I get a error warning in a new window that says: “ERROR: Link verification failed”.
I triple checked that I have the right Mal’s server (ww12.aitsafe.com) and the correct User ID. I also made sure the Verifying Links option is not checked in the Cart Setup in my Mal’s account.
I even went as far as creating a new account at Mal’s with a Payment Password that is exactly 6 characters long, which I read was a solution for another user who had the same Link verification problem.
