I am using expression engine in my personal site, but now my contact form built with FTG doesn’t work anymore.
Anyone know why? Contact page is here:
http://williammacdesign.com/index.php/home/contact/
Bill
Bill
Hi Bill,
The form tag, action and method are not being set, I don’t know why they are not getting set but that is why the submit button does nothing.
I haven’t worked with the expression engine so I can’t tell you any more i’m afraid, maybe someone with more experiance using the expression engine and forms may chip in.
Mike
thanks Mike. I tried to rebuild my form in FTG but the application doesn’t recognize non-html url’s so it won’t read the form fields.
I might be out of luck and not be able to use FTG for my forms if I stick with EE on my site…that would be a disappointment.
Bill
On Nov 22, 2008, at 9:45 AM, Mike B wrote:
Hi Bill,
Mike
Come to think of it, do you not need to set these yourself in Freeway
when using FTG?
Page > Form Set Up
Then set the action to the page/file the form is sent to and the
Method to POST
Mike
the page form setup is set to post with a php file generated by FTG.
I noticed the “upload stuff” action had been wiped, so I reapplied it
to upload the FTG php file for the form, still doesn’t work.
Bill
Freeway when using FTG?Page > Form Set Up
Method to POSTMike
IIRC, you’re currently using EE Core, right? When you upgrade to the full EE, you can just use the built-in Email Contact Form.
http://expressionengine.com/docs/modules/email/contact_form.html
I am just testing things out with the free version of the core, thanks
Joe.
Bill
full EE, you can just use the built-in Email Contact Form.http://expressionengine.com/docs/modules/email/contact_form.html
