I’m trying to upload a new site, only one page at this point. Host is Have Host. When I attempt the upload with Freeway I’m getting “Cannot connect because the FTP server is not responding”. I have several other sites at Have Host and I’ve never experienced this problem with any of them.
Could it have anything to do with the nameservers? I’ve changed the nameservers at my friend’s domain registrar to the Have Host names but its has not yet been 24 hours. Could that cause the FTP problem? Or do I have to look for another solution?
Thanks for your help.
Dave
It could be, but first check very carefully what text you have put in the Server, Directory etc fields.
It is worth deleting and starting again. Also check that you can get to the have-host server using the web address (rather than the previous server).
The nameserver change kicked in and I was then able to do the upload. So that appears to have been the problem.
Dave
