Julie1
(Julie)
March 5, 2010, 2:12pm
1
First,
THank you Rich Gannon for introducing this Action - I love the look more than the tiled background.
I am having 2 issues with this.
any input on fixing these will be awesome.
on safari - the picture is slow to load.
on firefox - I am not getting a picture at all - just a white background
http://www.babybootyshop.com
THank you for your help - you guys rock
Julie
Robert_B
(Robert B)
March 5, 2010, 2:37pm
2
Not sure if this has anything to do with it, but it looks like your background image is a Photoshop file. Assuming this camfade1.psd is it.
You can place PSD files, but not upload them for the web. This is apparently in your Resources folder which should only contain web ready files.
Bob
Julie1
(Julie)
March 5, 2010, 2:41pm
3
ok - so i should make it a gif or a jpeg? which would be better?
thank you so much
J
Bob
Robert_B
(Robert B)
March 5, 2010, 2:48pm
4
Not sure if that action requires one over the other, but whatever looks the best at the smallest size possible.
There’s not a lot of detail, being faded, so you might get away with a pretty small file with either format.
You just have to test a few.
Bob
Julie1
(Julie)
March 5, 2010, 2:54pm
5
I changed it to a jpg and that worked! thank you.
to all any tips on cleaning up the edges of the logo in the upper lt corner?
Thank you Bob!
Julie
Bob
Robert_B
(Robert B)
March 5, 2010, 3:09pm
6
Take the original logo file (AI or PSD, I guess?) and contract the edges.
In Photoshop, I would select everything, contract by 1 or 2 pixels an delete. This way you’ll get a clean no-white border.
Bob
Julie1
(Julie)
March 5, 2010, 3:11pm
7
original is a jpg
but i took the bkgrnd away in ps - i will go back in there and do that…
I had not seen that option - do you know where to find it in ps?
THank you
J
Bob
Robert_B
(Robert B)
March 5, 2010, 3:16pm
8
Here’s the steps I’d take:
Select the background (because it’s easier) then go to Select > Modify > Expand. Make the 1 or 2 pixel adjustment. Then look at you image to see if that’s enough to get rid of the border.
If it is, hit delete. Save for Web.
Bob
Julie1
(Julie)
March 5, 2010, 3:22pm
9
the background of the logo is clear so the actually background will show through
J
Bob
Robert_B
(Robert B)
March 5, 2010, 3:23pm
10
That’s OK. It should still select it.
If you still have a problem send the original file to me.
bob (at) theiguanaden (dot) com
Bob
