full background Proportional help
If it is, hit delete.
Yes. But don’t Save for Web. Instead, just save as a Photoshop document (preserving layers, transparency, etc.) and import to Freeway as normal. Freeway will do the Save for Web process for you automatically as it publishes, and you won’t end up using a second round of lossy, image-damaging compression.
k
Yes, we went through that in e-mails, Keith.
I told her to just import the PSD file.
Bob
What action does this thread refer to? Sounds like something I might like.
Thanks.
Thanks Keith -
i did save it as a psd and a gif.
When i did what is listed to do (you can see what I have )- I had no delete option… so i just saved -
Julie
http://www.babybootyshop.com
k
ps I ended up doing a lot in ill but still have an outline…
J
k
full background proportional
http://actionsforge.com/projects/view/75-full-background-image
Thanks.
yes we did and he is a hugh help!!!
J
*but I still have the damn outline - but much better thank you
Bob
List Options | FreewayTalk
