Guys, I can’t say anything specific because of the NDA, but I think I can say good news is on its way!
A small clue, please. You can’t leave us hanging like that!
If he’s taking it at all seriously, he can’t even tell you which NDA he means… I will break mine and tell you it’s not Softpress’s. Sadly.
Since this thread is about Sierra and “SoftPress” Freeway, the NDA in question would either have to pertain to SoftPress or Apple; otherwise Iain’s post would be off-topic and irrelevant. So I will assume for the moment it is Apple because I also found problems with another app called Online Bible (original created by Ken Hamel) and the developer sent out emails recently to say that they had contacted Apple about the issues and Apple should be addressing them in the next Sierra update.
–James Wages
OK guys, now that 10.12.2 has been released, hopefully you will all be happy that the issues we have talked about, here and elsewhere, have all disappeared!
For me, anyway!
I just updated to 10.12.2 and tested Freeway.
Some radio button elements show discoloration, but that does not affect functionality.
All said, it appears that Apple did indeed fix its broken stuff.
I tested on my 5K iMac at the office.
Oh, wow. That is good news James! I’m on a new MacBook Pro and I’ve experienced the same issues you have outlined above. I’ve not yet upgraded Sierra yet. Happy to hear this! Thanks for sharing.
Doty
I hope it will work fine on Macbook 13 retina.
I’am afraid to try
Do or do not.
There is no try!
–Yoda
I updated to the latest MacBook (Sierra, updated to 10.12.2, Retina Display) and after applying the OS update, here is my import dialog box:
Yes, Doty. As I have mentioned before, there is UI element discoloration, but beside that there is no problem under 10.12.2.
–James Wages
