After years of using FW, I suddenly have a problem with image size. Using non-CSS layouts, I insert an image into an edited page. The image is set for 100% quality, Bilinear & Anti-Alias with 15 px padding and floating left. It has been scaled to, for example, 40%. In FW it looks great, but in both Chrome and Safari, the correct image size appears, but, in this example, only 40% of the image shows.
This only occurs with the second or third images on a page. The first one continues to transform correctly.
Look like to me, that the 2nd image is being cut off to do either a overlapping problem or the text next to each image is too much. Did you try making the box for the text smaller?
The image is inserted within a larger text box. This is the way I have always done this, and for years it worked fine. As you can see, I am not a pro at this, so maybe I am missing something here.
