Sometime around 31/12/08 (at 14:31 -0500) SkipII said:
My biggest frustration is that things don’t seem to work as the
tutorial say they will – and many of the tutorials are focused on
Express, not Pro.
This does seem to be a definite weakness. Perhaps the tutorials can
be flagged more clearly as to whether they’re for Express or Pro, and
also maybe some Pro-specific ones can be added as well.
How to keep text from going all the way to the edge of text boxes.
This was actually answered, but it was a little brief.
Basically, the effect you want can be achieved by giving the box some
‘padding’. In design and layout terms this equates to the text inset
feature in Adobe InDesign or QuarkXPress.
- Select the box that contains some text
- In the Inspector palette (first tab), type “5” (without the
quotes) into the Padding field, found in the Dimensions section.
That’s all you need to do. Once you apply this (hit the Return or
Enter key or just click somewhere in your document) the text in the
box will be offset inwards by 5 pixels.
How to keep graphics from automatically combining.
Graphics will automatically combine if they:
a) overlap,
b) are not layered, and
c) don’t have their Combine Graphics box (Inspector palette) unchecked.
If two overlapping graphics are layered then each item will be output
complete, on its own, in the layout.
Transparent ‘cutout’ areas and translucent areas (shadows, etc.) will
be rendered using the page background colour. GIFs can use crude
1-bit transparency, but this doesn’t help with ‘partial’ transparent
areas such as shadow effects. PNGs set to millions of colours have
full 8-bit transparency that allows for true shadow translucency, but
the file sizes can be an issue.
If two overlapping graphics are not layered but the Combine Graphics
checkbox (found in the Inspector palette; select one graphic to see
it) is UNchecked then the graphics will be sliced up into a flat
jigsaw puzzle, cut along the borders of the graphic that’s set not to
combine.
This produces the sliced output that allows for rollover areas within
what appears to be a larger graphic.
I hope these pointers help.
k
