Hi everybody!
I’d like to experiment with the google open graph protocol. This is simply some code I should insert in the block.
I know this is trivial to do but how can I do that in FW? Is the “insert Markup item” smart enough to do that?
Here the example code from google page:
The Rock (1996)
Tx in advance!
Claude Bouillin
www.celticcenter.eu
You want the “HTML Markup” item in the “Page” menu.
All right. Sounds good, but is it smart enough to insert the code in the right place or is this relevant?
Claude Bouillin
You have the choice of "after " or "before , either of which should suit your needs.
The Page->insert HTML markup menu gives me a choice many places of insertion. The default is "before " . I don’t think this is appropriate in the case of the following code.
An alternative could to split the nested blocks in 2. Like this:
But i’ll have to edit this code and I am not keen on it… Any idea anyone ho I can simply insert this code in my page?
The Rock (1996)
Claude Bouillin
www.celticcenter.eu
JDW
(James Wages)
February 7, 2020, 7:41am
6
It’s now 10 years later and still no solution on how to add content INSIDE the HTML or HEAD tags using Freeway Pro 7.
FaceBook today in 2020 uses Open Graph which requires this:
<html prefix="og: <http://ogp.me/ns#">>
HTML Markup doesn’t allow us to do that. We need to add that “prefix” INSIDE the HTML or HEAD tags.
Believe me, I’ve tried the Action “solutions” to no avail…
Tim’s “Meta Plus” Action is ancient and still references Flash! Meta Plus - ActionsForge
Ian’s “Facebook Open Graph Meta Tags” Action adds the meta tags but then doesn’t change the HTML or HEAD tags as required! What the…! Facebook Open Graph Meta Tags - ActionsForge
How in THE world do we edit the HTML or HEAD tags in Freeway Pro 7?
—James Wages
Jeremy
(Jeremy Hughes)
February 14, 2020, 11:05am
7
Hi James,
Try using the “Better Meta” Action:
Jeremy
JDW
(James Wages)
February 17, 2020, 3:02am
8
Perfect solution!
Thank you, Jeremy!
–James Wages
