Hi all
Right then we have the hamburger icon for the pages in responsive mode is there anyway in freeway that you can have the hamburger icon on the default size page layout. this would be a great help
cheers
In addition or instead of? Bit more info required.
Looking at having the hamburger icon on the main page instead of the css menu text so that it shows on all screen options from mobile to desktop. Css menu option only allows for the break points and the image
Stephen
So you want a hamburger menu at all sizes? No text initially visible?
You’ve got it in one Dave. Looking at doing a card style website which I think will work better in responsive and in full page. People are now used to mobile navigation and if you’ve got cards for main categories then it will work so hence the hamburger icon on all sizes of pages to give it a uniformed appearance accross all platforms. If you know of some magic code it would be much appreciated
Stephen
As long as you have created a Breakpoint (Edit>Media Types) at a size you want you can then choose that Breakpoint (size) in the CSS Menu options set up and your Hamburger will show.
