I have created a Header and inside there is an image and a navigation area. Between the two areas there is a space, is there any way to eliminate this space and make the areas appear together?
Hi Grabusitja,
Most of the space is probably caused by a bottom margin on the paragraph that contains the image. If you select the image and press right-arrow on the keyboard, Xway will display the Paragraph Inspector for this paragraph. Setting the bottom margin to zero should remove most of this space.
You probably also need to change the vertical alignment of the image. The default vertical alignment is Baseline, which causes the base of the image to be aligned with the baseline of text—if you don’t have any text, the image is aligned with where the baseline would be. Changing the vertical alignment to Bottom should remove this remaining space.
Exact. This is what you mentioned. Thank you.
