Help CSS menu drop down
Hi - take a look
http://thekiteacademy.com/test/hire.html
The TUITION button has a drop down but you cant select the drop down because it disappears when you roll over? Its fine with inline stuff under it as here:
http://www.thekiteacademy.com/test/index.html
Please help!
Hi Justin,
Select the item top-barholder and select the Item>Bring to Front menu item.
Hope this helps,
On 11 Apr 2010, at 22:14, Justin Easthall wrote:
Hi - take a look
Please help!
great worked thanks
Jus
