HELP! CSS Menu Not Working on Win IE
Hi, running into some problems with my CSS Menu. Works great on my mac, but gets funky in Win IE 6.0.2. The drop down menu appears and then disappears. Unable to click on it to link to the page.
Please take a look:
http://www.kanemag.com
Any suggestions would be much appreciated!
What version of FW are you using.
I believe 5.12 (the latest) has a fix for this.
I’m currently using 5.12, pro…
This is belt and braces as this should be incorporated in 5.1.2 but why not give it a go.
This is actually caused by the bug that has been mentioned before.
Go to Page>Insert HTML and in the “Before ” section (the / is important) paste the following:
li { float: left; width: 100%; }
Do I do this for each page?
Try it on one and see if it works first.
If all the pages are based on the same Master then you can do it to the Master.
Okay, I tried it on all my Master Pages and it still doesn’t work…
any other suggestions?
Is there something wrong with the way I created the CSS Menu?
Hi Janel,
Your menus need a background color to work properly in IE and Opera,
this is unavoidable (afaik) and down to the difference in the way the
browsers work compared with Firefox and Safari.
I hope this helps.
I’m sorry Joe - I had assumed that the latest Fix for 5.1.2 had addressed that issue as well.
Hmm, I must be doing something wrong. I selected the css menu and as an “HTML item” made the background color black… still not working.
Website:
www.kanemag.com
Try setting the background color in the CSS Menu Action window.
Hi David,
The fix was for submenus not sticking in IE7 using vertical menus.
There’s no way to get round needing a background color on the menu
items in IE and Opera (afaik – if someone knows different then please
speak up :-)), it’s just the way they handle the CSS for the menus.
Thanks for all your help… however I’ve given up and redesigned my menu. As long as I get it to work. I’ll have to deal with the aesthetics later.
I’m having the same problem, but I’d really like to make this work. My site is here: www.johnbamber.com/new3 - my menus disappear when I move the mouse beyond the first submenu or so. I’m using one of the templates that came with freeway; I don’t know any CSS coding or anything like that, so I’m hoping this may be an easy fix. I tried adding the li { float: left; width: 100%; } as mentioned previously in this post, also tried adding background colors and that was unsuccessful. I’m testing it with the latest version of Safari, not sure if I’m doing anything else wrong. I’m getting quite frustrated… :frowning:
Hi John,
The issue you are seeing is because the menu is on a layer behind the box that contains your name (name:title). When you move down a sub menu the cursor passes over the title layer and dismisses the menu. The solution is to turn on Show Items in the Site panel (use the gear icon in the lower left hand corner of the Freeway window) and move the menu item below the title item in the list. Layered items lower in this panel will display above other items in the list.
Tim Plumb
Creative Director
Softpress Systems
Follow us on Twitter: http://www.softpress.com/tny/064
Join us on Facebook: Redirecting...
Looking for a webhost? We love these guys: Softpress » Web Hosting Partners
I can’t seem to reposition it… also there appears to be more than one of these. I thought this was supposed to be easy… lol.
Do I need to hold a key down in order to be able to move it? Also should I be moving it on the master page or the other ones?
On May 26, 2011, at 9:34 AM, Tim Plumb wrote:
Hi John,
Tim Plumb
Creative Director
Softpress Systems
Hi John,
Go to your master page and view the items in the site panel then drag the menu item below the title item in the view. This should re-stack the items with the menu above the title and the sub menus should work again. If you can see duplicate items in your page when looking at the site panel then it’s a good idea to eliminate the duplicates as they certainly aren’t needed.
Tim Plumb
Creative Director
Softpress Systems
Tried that, no good.
Here’s a screen capture of what I was doing: http://gallery.me.com/johnbamber#100833
Am I doing something wrong?
On May 26, 2011, at 9:45 AM, Tim Plumb wrote:
Hi John,
Tim Plumb
Creative Director
Softpress Systems
I am not sure which template you are using John but you can try this as well.
Select your Menu item in the site pane and from the Item Menu, select Bring to Front
Yep, bringing the menu to the front will solve this problem.
