Help with search results
Hi All
Looking at the google results for Prospect Fencing, how can I tidy up the description below each link?
thx
item 1 , item2 etc.
You will need to go through your FW pages and replace the FW generated IDs on all your items with proper names, Such as the Navigation Div which is called item4 - you can name these in the Inspector - do it on your Master pages.
Select a Div and look in the Title box - give them meaningful names/titles.
And then wait till Mr Google comes back round.
Thanks David
I have played around changing Meta tags and things, but no change in Google. Does it take a while for it to update?
I have also added a description and keywords with Meta tags, will Google pick these up the next time it updates?
many thanks
Paul
Yes doing the Meta tags etc. will help but NOT with the item1, item2 etc appearing in the descriptions.
Yes - it can take weeks!
