I have just updated my site at www.gymking.co.uk
(you will need to have a quick look at this)
As you will see the table on the right hand side is fine until the row under the free post picture. From then on the table is spaced out differently on each page, ie there are gaps between the table rows,
On Freeway the table obviously looks fine with all of the rows under each other, why does this change when it is uploaded ??
just been looking at my freeway file again and on all of the pages that are using my master 1 page the page rows are all different… (its only the left master table that is affected)…
The only way ive managed to change this is to go to each page and change the master to master 2 and then back to master 1 , now the layout seems ok, (although I havent uploaded it yet,
