When making a change on Master Page (css menu) it is not changing on the Home Page, but it is changing on all other pages. How do I correct this, so that the changes I make on the Master Page will reflect on the Home [Master Page]? Thanks for the help.
Hello,
Select your Home page and in the left hand pane of Freeway switch from Site to Page mode by selecting the heading (Site), Now you should see a detailed element view of the Home page in the Left hand Pane.
Now select the CSS Menu item and check the Inspector window for that item. Select the Left most item within the Inspector for the CSS Menu item and make sure you have Use Master Content Selected.
I think this is the issue you are experiencing …
John
John,
Thanks for responding. I took your advice and it did not correct the issue. I also tried to Reapply the Master under the Page menu and it still did not correct the issue.
I did make changes to the menu thinking that I was working on the master page.
I there something else I could try?
You may have broken the link with the Master.
Have you tried copying the Menu from the master and pasting into the child.
I did copy but the menu and it worked. Yet the menu is the only thing that is not linked to the master page. Very Strange.
I have often this issue when working on a site page, thinking it’s on the
master. And then changes on the master don’t reflect on a childpage. …
The solution is: cut the (e.g.) menu from the childpage and then from the
master, and reapply it back immediately on the master (FW can only
copy-paste one item). Voila.
2015-02-27 1:51 GMT+01:00 Grady Tracy email@hidden:
