On May 10, 2009, at 4:33 PM, Robin Barooah wrote:
Well, I’m glad you have confidence in the developers.
It is not a matter of confidence. As I mentioned, I have used
Intaglio for many years. I have also made requests for features. I
had to make a case for them but, once the developers were convince,
they were implemented fairly rapidly.
I agree that adding features to software for the sake of it
produces bad results, and that’s not what I’m asking about
The cost of purchase of something like intaglio is irrelevant
compared to the investment of time and understanding in using the
tool.
Absolutely true.
There are bugs in the existing version
Of course. But then MS Word lost me a whole chapter of a book because
their “long document” had a bug. I have yet to lose something with
Intaglio.
, and Apple will continue to develop their systems necessitating
maintenance and adaptation even if there are no new features needed.
So far, as far as I know, Intaglio has kept up with Apple.
On top of that, there are competitors who will draw resources
away from the developers if the product is seen as stale.
I don’t understand what stale means. If a software does the job I
bought it for and the software keeps up with the OS, I don’t see it
as stale.
I want to know that the tool I am investing time in is supported by
a viable company.
How do you define “viable”?
It’s a bad sign if this is hard to ascertain
How hard was it to ascertain the viability of, say, General Motors?
since it means that others will be deterred also, most of them long
before they think of asking a question, and you aren’t going to be
there to convince them of the attentions of the developers.
I don’t see where you are going here.
I think intaglio is the best product in it’s class but it took me
hours of effort to determine that.
How does one determine how anything is a good product in less than
hours?
This is also not a good sign.
I don’t see what this has to do with anything. These days, I use
LaTeX heavily and it took me months of use to begin to be just a bit
proficient at it and to experience its power. What does it prove
other than the fact that the learning curve of LaTeX is regrettably
steep?
An example of a feature that’s missing that I would like to see?
Boolean operations should work seamlessly on bitmap objects. No
additional UI or ‘design weight’ would be needed to make this work
but it would add a great deal of power to the application.
Of course, I can’t speak to that. Maybe the developer will. But that
would seem to have little to do with how alive Intaglio is as a company.
May I suggest that, in final analysis, you buy what you want and then
you live with it as long as you can.
Regards
–Schremmer
Intaglio mailing list
