How add Adobe Edge 1.0 animation in Freeway Pro 5.6.5 ?
Someone has an idea?
Thank you for your help;-)
I saw this website (www.madebyvadim.com) built in Freeway Pro which has integrated an Adobe Edge 1.0 animation…
I believe that this website was done by building it in Freeway and then opening and editing the Freeway-generated files to finish off the site using Adobe Edge animations. The main issue with working in this way is that if the site content changes at a later date, the work will need to be done in Freeway again and then the animation will need to be implemented all over again because that work was done outside of Freeway.
Here is the answer from Vadim;-)
"Its all the way around . I create the website in Freeway , a fully ready and operational AND then I open the index.html onsite the Adobe Edge and make the animation , the Adobe imbedded one line of code inside the html file and created a special folded with all the .js inside. Thats it. "
Animate doesn’t just create its own standalone motion graphics. In this lesson you will learn how Animate can open an existing static HTML page and then put elements on that page into motion.
