How do I add controls for a slide show
I have been creating slide shows with target actions in Freeway Pro, but I would like to ad controls to go back or forward or little boxes to click to go to a particular slide like this website.
Can I do this in Freeway or do I have to create it in Flash?
Thanks for any help
Have a look at Walter’s Carousel action
Thanks David for the suggestion.
That would work except that I don’t particularly like the scrolling of the images. I would like the next image to just replace the old slide or fade in like the target action can do.
Any other ideas?
Bob
