On 22 Feb 2007, 10:48 am, waltd wrote:
If there is separate JavaScript (in a block, with
maybe a function foo() type thing in it) then that should go in the
Page>HTML Markup>Before section. If there is JavaScript that
has to go on the page where you want to play the movie, then that
should go in a Markup Item on the page. More about that in the next
para.I looked at FlowPlayer, and that just seems to use a very slightly
extended SWF file – one extra parameter added for the “flashvars”. In
that case, all you would need to do is put their code for the flash
object into a Markup Item. Insert>Markup Item, paste the code, tweak
the variables to match your actual filenames, and then Okay the dialog.
Resize the 100px box you will see in the middle of your page, move it
to where you want the movie to play, and you’re almost done.In all of these cases, there is the problem of getting the movie(s) up
to your server. Enter Upload Stuff. This free Action from Tim Plumb[1]
can place additional files on the server, either in the Resources
folder or directly alongside the HTML. One caveat here – if you re-use
the same player swf on more than one page, don’t put more than one copy
on the server, because Freeway will rename one of them to avoid
filename conflicts, and anyway, it’s just a waste of space.Walter
Does this still work? I’m using Freeway 5.4.2 Pro.
I’m trying to get FlowPlayer to work and I’ve followed the instructions on their website as well as these tips from Walter.
Is there a conflict with some Freeway Actions? I’m getting an error when I Publish the page:
Publish Problems
8 December 2009 12:53:03
ACTION CANNOT BE USED. The following Actions have been incorrectly applied and will be ignored.
Action: “Transition FX”, Page: “Home Page”.
Action: “Target Show/Hide Layer”, Page: “Home Page”.
