Hi
CCS drop down menus are only a problem if they drop down over a slide show. They tend to drop down behind the the slideshow frame.
If you are viewing your slideshow with an iFrame you do not need to upload extras from memory. You have to upload the the whole folder to your server. When you action the HTML box as an iFrame you open the actions menu and route the iFrame on the option ‘Other’ to the index file of the slideshow on your server.
Hope that helps and sorry to take so long to reply
