I see in some sites made with Freeway an “E-mail us” button, and looking at the source code there is no e-mail address showing.
Example: www.thegourmetdog.com
How is this accomplished, is it an action?
Thanks for any help
It is there in the code:
mailto:#111;#114;#100;#101;#114;#115;#64;#116;#104;#101;#103;#111;#117;#114;"
It just doesn’t look like an email address because FW5 has an option in File>Document Setup> Output Email Hiding:Encode with Entities which converts your email address
kitesurfer(@)yoursite.com
to the gobbledy gook above.
Thanks David,
I can’t use:
because I would need a “script” in the CGI server to translate, or something of the sort.
I am a learning newbie, I would need to be pointed to where I can get a sample “script” to include in the server.
Can someone help?
Thanks a lot in advance!
Take a look at this example html link page. This is more or less what is going on with the mail to: link except that Freeway also scrambles the return address so it cannot be harvested.
If it is a simple ‘mail to’ link then there is no CGI scripting involved and any browser will read the encoded email address.
