Hi All
A client has asked to add a simple blogg style section on their website, which they can add to themselves.
Thought about doing a webyep panel on a page, but not sure.
Any tips on best option please.
Regards
Mike
Pulsecms.com have an easy to add Blog
Hi Mike this can be done using WebYep
but its not designed to be a massive blog system
but if you are comfortable with webyep and your client isn’t going to be creating thousands of blog items a year then yes webyep can do it
here is an example of using webyep as the blog system within a normal freeway/webyep website is this the sort of thing you meant:
http://www.sophieyershonphotography.co.uk/blog.php?DOC_INST=19
all the best Max
