Sorry if this is posted before, but I am a total newbie and I am not sure what to even search for. I want to make a sound player on my website, maybe something like the one found here: http://www.matseden.se/ (it’s in swedish, but in the link “lyssna” all the way to the right shows what I mean).
I have Freeway Pro. Is there a way to make what I want? I will be grateful for any help!
The sound player on that site has been created using Flash so you
would either need to create it yourself, or purchase one that has been
created and add your own content, both options requiring the Flash
application (not cheap) and learning how to use it (not easy).
You could quite easily use something along these lines in Freeway
though:
Let us know if you need any help using these and we will try to help
out as much as we can.
shows what I mean).
I am new in FW. I need the simple player which will not be buffering and playing automatically. Could you give me detailed instruction how to embed this player (Tutorial for Flash MP3 Player) in FW page. I will need several players at one page.
The instructions on that page are fairly clear. The main thing to remember is that the ‘code’ in the tutorial should be added in a markup item. Use Insert>Markup item and then paste the code for the player.
Each player will need to have a unique ID ie , audioplayer2, audioplayerr etc.
And you will need to upload the Other files to the server
