How to freely resize images?
In Freeway i just simpli take a corner and freely can resize images.
Also when i change size of page all my images resize too which i do not want.
Thank ü
Thank ü
Hi Sasha,
When you insert an image, it doesn’t have a defined width and height and can’t be resized (this is the same as pass-through images in Freeway). If you give the image a defined width and/or height, you can resize it by dragging one of the resize handles (as in Freeway).
To set a defined width and height, type a value (e.g. “200”) into the Width and Height fields in the Box Inspector.
If you want the image to preserve its aspect ratio (original proportions) when you resize it, type a value into the Width field but leave the height undefined.
The maximum width of images is set to 50% by default. This means that an image will not be wider than 50% of the width of its parent. If you don’t want the image to resize flexibly, you can delete this value.
Jeremy
Thank ü it works.
Is max 50% default image size is because to make web site Retina?
Also:
Not really, because 50% width (in CSS) is 50% of the parent’s width rather than 50% of the image’s width.
It’s more of a convenience feature - to prevent large images from being imported at ridiculously large sizes (as can happen in Freeway).
- I found annoying when you open Xway then a blank page opens.
Better will be if the last project you were working opens.
That’s standard Mac behaviour (most applications do this) but you can use the "Close Windows when quitting app” setting in the General panel of System Preferences to change this: if this is unselected, applications should reopen any windows that were open when you quit them.
- I understand that to port projects from Freeway to Xway will not be done because it will require anormus work and basicly to rewrire Freeway from ground up to make Freeway presents port to Xway,
but alist if you will add and option to port web site pages from Freeway to Xway with out ability to edit them in Xway. And if you want to edit some of those pages in Xway then you need to redo those particular pages in Xway.
We do plan to import Freeway documents in future. But we need to support most of the same functionality before we can do that.
Importing read-only versions of old HTML pages is an interesting idea. It might be possible to use iframes as a way of doing this - but I think that link management could be a difficult issue to deal with.
You can also use external links to link to pages that Freeway has published.
- For me right now Xway is usless with out working upload to web site.
So hopefully in next beta it will be working
We also plan to add upload in future, but it won’t be in the next beta. In the meantime, it’s quite easy to upload web sites with a third-party application (Transmit, Cyberduck, etc.):
Jeremy
Go to thread 336 on here.
Close Windows when quitting app is selected in setting in the General panel of System Preferences but Xway still opens a blank page at start up.
Because in my user scenario i am usualy working on previus web site i was working.
That’s what I would expect to happen if "Close windows when quitting app” is selected.
What happens if "Close windows when quitting app” is turned off (not selected)?
Jeremy
I both ways a blank page opens
What is supposed to happen (and what happens for me with Xway and other applications) is that if you have "Close windows when quitting app” turned off, then any windows that are open when you quit an application will be reopened when the application is restarted.
If you close them before quitting, they won’t reopen.
Jeremy
How to arange order of images in Xway?
Hi Sasha,
It’s not currently possible to rearrange the order of images (e.g. by dragging). We will add this in a future version.
A current (tedious) workaround is to reimport images in the order you want to have them.
Jeremy
That is what i found lol
Post scriptum:
Do you have any guess when full relise of Xway will be ready?
Our plan is to release a series of beta versions over the coming months.
The ability to drag inflow items probably won’t be in the next beta version (b2), but it is likely to be in b3.
Jeremy
You can make 1 image to scale according to web browser windows size.
But how to group 2 differnt images so they act as 1 image to scalling of web browser windows size ?
For the moment, you could use Photoshop or Acorn or Pixelmator. Combine the two images on a single canvas, and export them together as a single image in a web-friendly format.
Yes i know that. But the problem is that for example.
There is an image of house with door.
I want that clicking on the door would a person to another page of web site.
But clicking on something else rather then door would do nothing.
So that’s why i created to separate images.
And image with door has a link to another page while image of house has nothing.
