Hi,
Simple question:
how to lock the stroke width, color, etc. ?
bw,
Omar KN
Intaglio mailing list
Hi,
Simple question:
bw,
Omar KN
first select a tool, don’t use it, it needs just to be selected,
then set color/ width / line style or anything
then use a tool
every time you will have the tool set with these atribites
if you click or simply use a tool before setup this will work just for this only one time use ![]()
Thank you, abrax, this was the smooth solution!
okn
