Q: “I’m building my first web site, I’m a photographer and I need the
photos on the site to be good quality but not too big a file size. Does
anybody know the best way of ensuring the photgraphs that I use can
still look good quality @ 72dpi. I am using Photoshop and everytime I
reduce the resolution to 72dpi the quality goes haywire”
A: Reducing
a really large scan to a small image suitable for a web page is not as
simple as changing the size in Freeway or Photoshop. You can get
acceptable results, but usually the details will become “mushy”.
One
trick to avoid this is to reduce the image in a series of steps. If you
are starting out with an image that is 8 times as large as you need it,
start by reducing it by 50%. Then apply a small amount of Unsharp Mask
in Photoshop. Then reduce by another 50%, and apply the Unsharp Mask
again.
Keep doing this until you get within 50% of your final
size, and make the final jump exactly the percentage needed to make
your finished size. Apply slightly more Unsharp Mask as the final step,
and then export as a JPEG. The image will appear sharper and more
detailed than if you simply resized it in one giant step.
