I have made a small PHP block with only a simple IF statement in it. The PHP block has a graphic item inside with a hyperlink on the image.
The PHP block itself works since I can see the graphic item, what doe not work however is the hyperlink.
If I check in Freeway itself the graphic item has an hyperlink, if I upload the file there is no link. Also when I check the generated PHP file there is no tag on the image.
This is known behavior, and it’s hard to say whether it should be
considered a bug or not. Freeway generates an Image Map rather than an
A tag for any non-rectangular image. You can get the rounded corners
and the non-map link by exporting the image from Freeway and then
importing it as a pass-through.
On Oct 9, 2010, at 3:08 PM, Julian wrote:
Found it! This must be a bug!
If you make a rectangluar graphic item with rounded edges hyperlinks
will stop working. Very weird…
