i think its done!
Ok Ladies and Gents,
Thank you to all the help from Paul and DeltaDave!!
I think it is done!
but if some one catches something let me know…
I also want to hear your thoughts on looks styles etc… please
I do have one thing I want to add - forget how…and its easier right
now to just ask then look for the answer (LOL)
is meta tags.
Thank you ALL
Julie
http://www.grassrootsweb.net
Much better Julie - but - the green box on the About Us page is to the front and no text is visible.
On the Contact page - remember what I said about making your Choose One selector - Initially Selected
Also do you have the Medical Office and General Practioner selectors in the same table cell? - if so then create a new row for the GP one - it will make it neater. Also ensure that all your rows/cells are the same height.
I think it is done!
Lots of dead links; eg: on the Welcome page, the ‘About us’ and
‘Services’ links don’t work, aren’t links.
Unlike Dave though, I do see text in the green box.
best wishes,
Paul Bradforth
http://www.paulbradforth.com
Paul,
That is weird! Does anyone else have problems w those links?
I checked them in freeway and the words are all set as having links to
the other pages…
I think it is done!
best wishes,
Paul Bradforth
Have you used a separate item for each menu link? If so, make sure you
don’t have any overlapping items or the container (DIV) for any other
item in front of the menu. I would use the built in CSS Menu Action on
a Master page to prevent this problem and ensure even spacing.
Colin.
On 20 Aug 2009, at 14:04, julie maxwell allen wrote:
Paul,
to the other pages…
I think it is done!
best wishes,
Paul Bradforth
Colin,
good morning
What I did was:
Each menu item is a separate HTML box. I highlighted the word and
added the link to the other page.
The only time there is an overlap is before the puzzle pieces move.
DIV?? can you explain?
I will try that.
thank you
Julie
you don’t have any overlapping items or the container (DIV) for any
other item in front of the menu. I would use the built in CSS Menu
Action on a Master page to prevent this problem and ensure even
spacing.
Colin.
Paul,
to the other pages…
I think it is done!
best wishes,
Paul Bradforth
In simple terms, DIV is just another name for the HTML box in which
you add your text (or an image) and is the term used in the actual
code. Don’t ask me to explain further - I’m not a coder, which is why
I use Freeway!
Make sure your menu item layers are at the top. In the Site Panel they
should be the bottom of the list of items on each page signifying they
were effectively the last added (i.e. the top layers). That may sound
confusing, but it’s the logic of listing the items from the bottom one
first.
Try grouping them: shift click to select the menu items then go to
Item Menu > Group, so that they all sit in one ‘container’, which can
be easily kept as the top layer.
Or you could set them in a table.
Colin
On 20 Aug 2009, at 14:32, julie maxwell allen wrote:
Colin,
good morning
What I did was:
I will try that.
thank you
Julie
spacing.
Colin.
Paul,
links to the other pages…
I think it is done!
best wishes,
Paul Bradforth
Is anyone else having trouble accessing www.actionsforge.com???
why I use Freeway!
they should be the bottom of the list of items on each page
signifying they were effectively the last added (i.e. the top
layers). That may sound confusing, but it’s the logic of listing the
items from the bottom one first.
can be easily kept as the top layer.
Colin
Colin,
good morning
What I did was:
I will try that.
thank you
Julie
any other item in front of the menu. I would use the built in CSS
Menu Action on a Master page to prevent this problem and ensure
even spacing.
Colin.
Paul,
I think it is done!
best wishes,
Paul Bradforth
It seems fine here.
why I use Freeway!
the items from the bottom one first.
Colin
Colin,
good morning
What I did was:
I will try that.
thank you
Julie
sure you don’t have any overlapping items or the container (DIV)
for any other item in front of the menu. I would use the built in
CSS Menu Action on a Master page to prevent this problem and
Colin.
Paul,
I think it is done!
best wishes,
Paul Bradforth
Working OK here …
best wishes,
Paul Bradforth
And here - no problems reaching http//:www.actionsforge.com first shot.
Colin
On 20 Aug 2009, at 15:30, Joe Billings wrote:
It seems fine here.
which you add your text (or an image) and is the term used in the
actual code. Don’t ask me to explain further - I’m not a coder,
which is why I use Freeway!
to Item Menu > Group, so that they all sit in one ‘container’,
which can be easily kept as the top layer.
Colin
Colin,
good morning
What I did was:
and added the link to the other page.
I will try that.
thank you
Julie
in CSS Menu Action on a Master page to prevent this problem and
Colin.
Paul,
I think it is done!
and ‘Services’ links don’t work, aren’t links.
best wishes,
Paul Bradforth
Humm… cant get on… I ahve tried safari, firefox and cleaned the
catches too…
this is the message: Safari can’t open the page “http://www.actionsforge.com/
” because the server where this page is located isn’t responding.
any hints?
I dont have the css menu action and some others I should have and am
trying to update.
Julie
shot.
Colin
It seems fine here.
the actual code. Don’t ask me to explain further - I’m not a
coder, which is why I use Freeway!
Colin
Colin,
good morning
What I did was:
move.
I will try that.
thank you
Julie
(DIV) for any other item in front of the menu. I would use the
built in CSS Menu Action on a Master page to prevent this
Colin.
Paul,
I think it is done!
best wishes,
Paul Bradforth
The Forge is humming along nicely here too. As to the CSS Menu Action,
you won’t find it there – that’s a core Softpress Action, and it’s a
part of Freeway itself. If you can’t find it in your menus, you’re
probably looking in the wrong place or you have a seriously old
version of Freeway.
catches too…
any hints?
trying to update.
catches too…
any hints?
The fault most be local. Are you having trouble with any other sites?
(Goes straight there from your link above).
trying to update.
The CSS Menus Action comes as a standard Action in Freeway Pro. So you
should have it (or are you using FW Express?).
Draw an HTML box and, with it selected, go to the menu Items> Actions
and it should at or near the top of the drop down list…
Just type you navigation menu headings as a list, indent only once and
leave on default, for bullets etc. In the Action panel you can set
spacing, colours, etc.
HTH Colin
Perhaps the Domain Name Server(s) (DNS) that your Mac is using through
your Internet provider might be in the middle of an update that just
happens to cause www.actionsforge.com to be temporarily unavailable
via your Internet provider. It might clear up in a little bit. You
also might try restarting once in a while to clean up the DNS cache.
catches too…
any hints?
trying to update.
Julie
shot.
Colin
Joe Sporleder, Technology Coordinator
McGrath Publishing Company
PO Box 445 • Beloit, Kansas 67420
785-738-2424 • Fax 785-738-5823
800-530-5496 • Toll Free Fax 800-471-1816
Mobile: 785-738-7396
email for advertising submissions: email@hidden
Thanks Joe and everyone else…
through your Internet provider might be in the middle of an update
that just happens to cause www.actionsforge.com to be temporarily
unavailable via your Internet provider. It might clear up in a
little bit. You also might try restarting once in a while to clean
up the DNS cache.
catches too…
any hints?
am trying to update.
Julie
shot.
Colin
Ok The links are done… I did not use CSS menu, sorry Colin, but I
dont have a list with them for it to activate
And Walter, I was trying to attach it to a table and it would not
show… not avail for tables I guess. I am using the most recent
version 5.4.1 ?
Julie
So how does it look??
Thank you for all help
shot.
Colin
It seems fine here.
Colin
Colin,
good morning
What I did was:
move.
I will try that.
thank you
Julie
Colin.
Paul,
I think it is done!
best wishes,
Paul Bradforth
You can make your navigation into a list, so you can use the action.
Just type out your links, hitting return after each one, select all,
indent in the Inspector, apply the CSS menu action, go to the Actions
palette and choose to show it horizontally.
best wishes,
Paul Bradforth
Is it working now or do I need to do that?
BTW Paul got the book!!
Actions palette and choose to show it horizontally.
best wishes,
Paul Bradforth
What do you mean?
Excellent, you’ll love it.
best wishes,
Paul Bradforth
