Iframe Color
It doesn’t. I think that’s generated by LR. May have to resync the gallery files.
Bill
------Original Message------
Sender: email@hidden
To: email@hidden
ReplyTo: email@hidden
Subject: Re: Iframe Color
Sent: Apr 26, 2010 16:19
Gee, I’ll have to check when I get home and can get into FW…give me an hour or so!
No need I see it is item3 - just checking that the bg color was applied properly.
Might be worth trying background-color:#000000
No idea if it will make any difference.
Just check something else will you Bill - unrelated.
There is a graphic http://billmccarroll.com/gallery/hdr/resources/misc/shadow.png which doesn’t display. Is it OK your end?
Sent from my Verizon Wireless BlackBerry
