Hi Trey
can you just send me a version of your artwork with just those tow pages? then I can have a proper look
cheers max
Hi Trey
cheers max
ok it turned out be html document type of 4.01 you need to set that to a modern document type of html 5
plus you had a reference to jquery in the head so I removed that because the action adds that already
plus I moved the references from Before to after After
so it your links look like this
<link rel="shortcut icon" href="http://ohair.com/favicon.ico/>
<link rel="icon" type="image/png" href="http://ohair.com/Resources/favicon.png">
<link rel=βiconβ href=βhttp://lightbenders.com/mobile/favicon.icoβ/>
<link href='https://fonts.googleapis.com/css?family=Raleway:100,200, 300, 400|Oxygen:400,300' rel='stylesheet' type='text/css'>
that way then the jquery script and references get added after the stuff above
Then I added space in the target div because freeway may apply a font size of 1px to an empty div.
So that you can see the result I created a new text style and applied it to the target div
kind Regards Max
You are an ace.
thats ok
speak soon max
just seen something in your references its the curly double quotes on the third line
and that will muck things up
so here it is again corrected to normal double quotes
<link rel="icon" href="http://lightbenders.com/mobile/favicon.ico"/>
Hi
this is an update to the action
this one allows you to target up to three different original blocks and copy the contents into 3 new blocks
you basically apply the action to 1 div and just reference the others within the action palette
you can also choose to include or not the jquery reference so thatβs just in case you have already written it into the head
kind regards max
