Help! I am importing photos from PhotoShop CS3. These are jpeg (will be using pop-ups). The photos are created as I always do. However, when pulled or imported onto the page (Freeway 4 - latest) they are half or less the size that they should be. Any idea what the problem is?
Tobé-USA
Just a guess… check the resolution of the photos in PS, I bet they
are 300 pixels / inch (or similar), if you change that to 72 then they
will probably be the same size as FW shows them.
the problem is?
Does this problem follow when you draw a new Graphics box using the
graphic box tool and import the photo using Apple E? Graphics boxes
“stick” to whatever percentage was last used in them, so if you are
re-using a box that already held a graphic that had been resized
down, the next image you import into it will be scaled to the same
percentage.
percentage.
Also, when working in PhotoShop I find that on some of the images, I cannot save them in jpeg. Only Tiff or Photoshop. The ones I am finally getting in Jpeg are the ones that will not work.
Tobé Saskor Websites and Photography by Tobé
59 Deerwood Lane
Pinehurst, NC 28374
Tel: 910-215-8818
Email: email@hidden
percentage.
when you change them to 72 dpi do you have the resample box checked? this changes the pixel size, make sure the pixel dimensions are still what you want them to be before you complete the resize image.
i.e. if you take a image that is 300 dpi and change it to 72 and have the resample on, it drastically reduces the pixel size of the image…
I need to do jpeg so that i can use pic to new window for enlargements. Otherwise I could use ones twice the size I need as they then come out about right.
59 Deerwood Lane
Pinehurst, NC 28374
Tel: 910-215-8818
Email: email@hidden
Tried it. Then you cannot change the original size. These came in too large. The one i have the most trouble with is one that I created a long photo consisting of three smaller ones side by side. The layers have been flattened. But it will not let me choose jpeg -only tiff or photoshop. I can pull it onto the site in the large size and it comes out about half that size. This is really weird!
59 Deerwood Lane
Pinehurst, NC 28374
Tel: 910-215-8818
Email: email@hidden
Tobé, I don’t mean this in a derogatory way, but
I think you need to put some time into
understanding image resolution and how it is
controlled in Photoshop, and then how that works
in print-oriented DTP apps and in Freeway. It
isn’t all quite as obvious as many people first
think, and it does sound like you’re hitting
problems in this area.
If you need to have an image for the Pic to New
Window action, by all means make JPEGs. But FIRST
make sure they are the right PIXEL dimensions in
Photoshop. For this use, it really doesn’t matter at all what the ppi setting is… The ONLY
thing you should care about is how many actual
pixels wide and tall your image is.
Once it is the right size, and it looks correct
when viewed at 100% in Photoshop (and you’ve done
any final sharpening), then use the File menu’s
Save for Web (or Save for Web & Devices) command
and generate a web-optimised JPEG.
For your thumbnails, you can either import the
image you just created above, then scale it to
fit a smaller box in a Freeway page, or create a
separate smaller image.
Yes you can. Just enter a new pixel size in the top fields. Try this:
open File info, then uncheck the ‘resample’ box if it’s checked. Then,
if you’re altering the resolution, enter 72 in the resolution field;
this will alter the sizes in the middle pair of fields, cm, inches etc
but will not affect the pixel size. Then check the ‘Resample’ box, and
enter the size you want in pixels in the top ‘Pixe’ fields. Remember,
the pixel size is the only one that matters
is really weird!
Is the file in 16bit? That would stop you saving a JPEG. Go to the
Image>Mode menu item and have a look …
is really weird!
