Hello,
how can I write an index or an exponent in a text ? (H2O, E = mc2) I
don’t find the text attributes inspector, where is it ?
jacques
Intaglio mailing list
Hello,
jacques
I don’t find the text attributes inspector, where is it ?
I have found something, but it was not easy : on my imacG5 the text
inspector is in the panel >fenêtre>remplissage>texte ; on my ibookG4
it is in >fenêtre>règle de texte ; why the difference ? how can I
change it ? under >remplissage it is not logic !
iMacG5 20" — iBookG4 14" — MacOS X 10.4.11 — Intaglio 3.0.1
jacques
I don’t find the text attributes inspector, where is it ?I have found something, but it was not easy : on my imacG5 the text
ibookG4 it is in >fenêtre>règle de texte ; why the difference ? how
can I change it ? under >remplissage it is not logic !
I had certainly inadvertently moved the panel ; now I have dragged it
in the right place ; it’s OK
jacques
OSX enables special characters (including Exponents) to be entered in several different ways.
The characters in a font can be seen and accessed from the Character Palette (Edit menu).
Open the Character palette and double-click the character. Alternatively, drag the character into the document.
Alternatively, use Unicode. Hold down the Option key and type ‘00B2’. The standard 2 is replaced by the Superscript two character (also known as a ‘Superior’).
Some fonts contain a features menu from which special characters can be accessed. Open the Font Panel (Command-T), click the ‘gear’ icon and choose ‘Typography’ from the menu that appears. The menu lists the font features for the current font. If a ‘Vertical Position’ feature displays, click the ‘Superiors’ button.
in several different ways.The characters in a font can be seen and accessed from the
Character Palette (Edit menu).Open the Character palette and double-click the character.
Alternatively, drag the character into the document.Alternatively, use Unicode. Hold down the Option key and type
(also known as a ‘Superior’).Some fonts contain a features menu from which special characters
Intaglio > Scripts > Convert to Superscripts
Regards
–schremmer
Hello Alain,
It is exactely what I want, thank you very much ; I am going to see
the other scripts too ![]()
best regards
jacques
Hello Ian,
The unicode super and subscripts does’nt exist in each font, nor for
each digit and letter, so I had to use the modification of the
baseline and of the size, for what the scripts are very convenient.
It does’nt work or I don’t understand how to make this
best regards
jacques
Unicode method:
Nothing happens until you type the 2. e=mc then appears, followed by 2 Superior.
Most fonts have 3 Superior numerals—1, 2 and 3. In the font they’re called Superiors, but the Character Palette calls them ‘Superscript’.
To find out if a font has the 3 Superiors/Superscript characters, open the Character Palette and scroll down to the rows numbered 230 and 240.
Some fonts also have superscripts of 4-9 and 0.
The Unicode can be seen in the yellow label that appears when you click a character in the Character Palette.
Alternatively, click a character in the Character Palette and drag it into the document.
When I use RagTime
Le 15 oct. 08 à 23:15, IanB a écrit :
Unicode method:
- Select Unicode Hex Input.
I don’t find where I can select this item
perhaps there is a difference between my mac os (I have Tiger
10.4.11) and yours ?
jacques
"When I use RagTime”
I don’t know Ragtime…
To configure Unicode Hex Input:
Unicode Hex Input will now appear after the default keyboard in the keyboard menu. To activate the Unicode keyboard, select it. Typing Unicodes with the Alt key held down should now work.
I prefer Thelonious Monk ![]()
now it is OK, thank you very much
jacques
“When I use RagTime”
Ragtime is an integrated word processing,
spreadsheet. drawing, etc. application from
Germany. It was first imported to the US in he
mid 90’s but not a lot of effort was made to
promote it and it was crushed by MS Office. I
see that it still has a US distributer.
I don’t know RagtimeŠ
Ragtime is an integrated word processing, spreadsheet. drawing,
etc. application from Germany. It was first imported to the US in
he mid 90’s
In fact, I would say, a few years after the Mac was born, i.e. late 80s.
Regards
–schremmer
The current version is 6.0.2
A new version 6.5 has been announced for the end of 2008
I use RagTime for many years but I wonder that Ian remembers it
jacques
he mid 90’sIn fact, I would say, a few years after the Mac was born, i.e. late
80s.
Ah yes, but iWork does all this and more, yet only costs £70.
I’m also a big fan of Tables and Merlin2
Sorry for the OT! ![]()
Ragtime is an integrated word processing, spreadsheet. drawing, etc.
application from Germany. It was first imported to the US in he mid
90’s but not a lot of effort was made to promote it and it was
crushed by MS Office. I see that it still has a US distributer. http://www.ragtime-online.com/
I’d forgotten, but about ten years ago, I was given a Ragtime CD at a Mac Expo! I still have it (it’s version 4.0.1) and it should work on the G5 iMac. I’ll have a look at it tomorrow.
Thelonius Monk…the top jazzmen are great musicians, but my favourite music is the blues/rock of the late 60s-early 70s. There are some great clips on YouTube of Zeppelin, Wishbone Ash and Free playing live. Wonderful stuff.
Glad you got Unicode working. Few users know about it and because it’s such a painful, complex way of accessing special characters, fewer care. The OS and font programmers seem to love it, however!
The font palette of RagTime 6 is very convenient to work with Unicode
(still more than those of MacOS X), and I use it often, but I did not
know the way of typing characters by hex input
jacques
