I am redesigning a home page with inline divs. When I paste in a div - containing text and a couple of images - the text and image links work fine until I set the float to left. And then the links don’t work.
Can you post the bad page temporarily? I can tell more from the HTML
than anything else. When you do, please be sure that the More Readable
setting is chosen in the Output pane of the Document Setup dialog.
On Jan 26, 2011, at 12:20 PM, Graham Meigh wrote:
No corner effects. The divs work fine as layers and when pasted
inline. But not when float left is applied.
Hi Graham,
It looks like the div called “item12” is covering most of the page and covering the links. See if you can shuffle this to the back or rework the layout to avoid this layout.
On 26 Jan 2011, at 17:49, Graham Meigh wrote:
There should be links on the book titles, images, more> and baskets.
Figure out what is item12 in your layout. It’s a very large HTML box,
it’s positioned above the elements that contain the links, and it’s
trapping all clicks on the lower part of your page. This doesn’t have
much to do with floats per se.
The reason I couldn’t sort this is because item12 is just the div containing: “There’s a fabulous selection of recipes available on our blog. Here’s a taster…”, the recipe images and titles - towards the base of the page.
How it was covering most of the page is a mystery! However, I have given it a float left and a definite height.
Thanks again. Don’t think I would have solved this on my own.
Here’s what Tim and I both did when presented with your page and the
identity of one of the missing links:
Control-click the element in question, and select Inspect Element from
the contextual menu. (We’ve both got the Develop menu enabled in
Safari – it’s in the preferences – so we see that option.)
That opens a little window or pane showing the rendered HTML at that
point, but more importantly, highlights the chosen element in blue on
the visible page. In your case, we saw that most of the page was blue.
This is a simple PHP powered form that grabs (curls) the specified web page, sets a tag (so that the page can use all of the images and scripts directly from the server) and then forces the file to download. The upshot of all of this is that I can open the downloaded HTML page in a text editor and start to tinker with the code knowing that when I preview it locally it will render as if it were on the server still.
There is even a bookmarklet on that page (dear it to your bookmarks bar in your browser) so you can download any page you are looking at simply by clicking on the link.
On 26 Jan 2011, at 18:14, Walter Lee Davis wrote:
That opens a little window or pane showing the rendered HTML at that point, but more importantly, highlights the chosen element in blue on the visible page. In your case, we saw that most of the page was blue.
