I designed a site for a client and their IT department wants me to insert web analytics code in the body section of the html. How do I do this since we’re using WYSIWYG.
Well i know google analytics code must be entered before the tag. So, select the page it needs to go on (usually the home page) and goto ‘Page’ and select ‘HTML Markup’ and then you can paste your code in there.
Make sure you select either ‘Before’ or ‘After’ according to where it needs to go before you paste the code to make sure the location is set properly.
