Hi Joe,
If this was me I would create a dynamic site using Freeway, PHP
scripts and a MySQL database back end.
I would have an admin area where I could login then add locations of
outlets or delete and edit them as needed, you could also add the
number of publications each outlet distributes every month… although
that might take you some time if you have 700 outlets to update every
month unless switched to using the online MySQL database for adding
the delivery information to or you put it all together with Filemaker
and took advantage of the FM database.
In reality what you need is not very complicated for someone who works
with PHP MySQL but to do this yourself would mean a fairly steep
learning curve, although one that will give you a lot of satisfaction.
If you wanted to learn more on learning PHP and MySQL there is a great
book called: PHP and MySQL Web Development, ISBN 0-672-32525-X
I have some examples of using PHP and MySQL with Freeway here:
http://www.easibase.com/freeway/phpmysql.php
Now a few years ago there was some information and actions for using
Freeway with Filemaker, in fact someone was asking questions about the
same not too long ago so maybe do a search and see what they turned up
as I can’t remember what the outcome of the thread was. One of the
advantages of using PHP and MySQL over Filemaker id the cost of
running things, using PHP with a MySQL database doesn’t cost you
anything while Filemaker hosting is fairly expensive as far as I can
remember.
HTH
Mike
On Sep 3, 2008, at 9:01 PM, Joe Sporleder wrote:
I am the publisher of The Kansas Senior Times, a monthly newspaper
for active, older adults in Kansas. We deliver to over 700 locations
across Kansas by Post Office and also our own drivers. I have the
delivery information in a real simple FileMaker database.
I do have access to MySQL and PHP for my website, but don’t have a
clue about either one. I would love to be able to have someone come
to the website, type in the name of a town in a search field, and
then been shown the Name of the place, the address, and perhaps the
quantity of papers for all of the places we deliver to in that town.
What is the simplest way to do this, using Freeway Pro, of course?
