In many instances wrapping your thumb around the neck to fret the 6th or 5th string is necessary. Is there a symbol that can be inserted to indicate a Thumb on a particular string/fret?
Hi Mark,
Yes, you can use “T” for thumb:
- Choose Edit Fingering from the Box menu
- Click on the note whose fingering you want to edit (or press Tab to get to it)
- Press “T” or “t”
Here’s an A chord with a thumb on the sixth string:
Excellent! Thank you!
