js Active Class
This is turning into a big ol’ red herring. I’m trying to use jQuery to add an ‘active’ class to a basic menu (to either the li or a tag) that’s generated from a Pulse Block. Über simple.
<ul class="menu">
	<li><a href=“/">Home</a></li>
	<li><a href="/company.php">Company</a></li>
	<li><a href="/contact.php">Contact</a></li>
</ul>
I’ve tried numerous jQuery examples but none of them work for me and I’m not sure why (yes, I’m calling jQuery before the link script). Does someone have a vanilla js solution I can try? Something that won’t conflict with jQuery.
dynamo mailing list
Here’s the classname stuff from Prototype, with all of its prototype-ness taken out of it so it can’t conflict:
To use this you would get a reference to the element you want to modify, and then pass it to the addClassName function, like this (pure vanilla js):
var selected = document.querySelector('ul.menu li:nth-of-type(2)');
addClassName(selected, 'active');
That should get you the second li marked as .active.
PS: You have a quote mark in there that doesn’t match – I think the first one is curly, not straight “typewriter” quotes. When I pasted your example into TextMate, it freaked out and the whole rest of the document was badly-colored.
<ul class="menu">
</ul>
http://xiiro.com
dynamo mailing list
dynamo mailing list
Thanks Walter, I managed to get the below jQuery script working. One catch though: despite the example on the dev site http://bit.ly/1fs3FwI which uses relative links (.html) my menu only works with absolute urls (.php). Any idea why this is happening?
Call
$(".menu a").currentPage();
Script
/* jQuery plugin for setting the class of a particular element to
 * "current" based on the current page. Useful for navigation menus
 * that are part of a server side include for the whole site.
 * By Rob Watts, http://tractionsys.com
 * Version 1.3, May 10, 2011
 * Modified by Chris Osborn, http://tractionsys.com
 * Version 2.0, Dec 16, 2011
 * Now constructs complete URL and compares to current location
 * Provided under the MIT license. Feel free to use it however you like.
 * Example:
 * $("ul.nav a").currentPage();
 * To override defaults, pass in a defaults object:
 * $("ul.nav a").currentPage({
 *    attr: "href",
 *    defaultClass: "selected"
ME_cpBase = $('base').attr('href');
ME_cpPath = window.location.href;
function ME_cpCompleteURL(base, path, index, uri)
  var array;
  var i;
  /* This looks stupid but it's the easiest way to make sure uri is a string */
  uri = uri + '';
  if (uri.indexOf(':') < 0) {
    if (base == undefined)
      base = path.substr(path.lastIndexOf('/') + 1);
    if (uri.charAt(0) == '/') {
      i = base.indexOf(':');
      i = base.indexOf('/', i + 3);
      uri = base.substr(0, i) + uri;
    else
      uri = base + uri;
  if (uri.search('/\\.\\./') >= 0) {
    array = uri.split('/');
    if (array.length > 3) {
      for (i = 4; i < array.length; i++)
	if (array[i] == '..') {
	  array.splice(i-1, 2);
	  i--;
      for (i = 3; i < array.length && array[i] == '..'; i++)
      if (i - 3)
	array.splice(3, i - 3);
      uri = array.join('/');
  if (uri.charAt(uri.length - 1) == '/')
    uri = uri + index;
  return uri;
jQuery.fn.currentPage = function(options) {
  var currentPage = "";
  var thisClass = "";
  var thisHref = "";
  var settings = jQuery.extend({
    defaultClass: "current",       // Default class to add to current link
	attr: "href",              // Default attribute to compare with current page URL (not usually used)
	appendToFirstClass: false, // Append the defaultClass to the first class on the element.
	                              // E.g. class="monkey" becomes class="monkey monkeycurrent"
	indexFile: "index.html"
	}, options);
  currentPage = ME_cpCompleteURL(ME_cpBase, ME_cpPath,
				 settings.indexFile, window.location.href);
  this.each(function() {
      thisHref = ME_cpCompleteURL(ME_cpBase, ME_cpPath, settings.indexFile,
				  $(this).attr(settings.attr));
      thisClass = "";
      if (thisHref == currentPage) {
	if (settings.appendToFirstClass) {
	  /* Conditional to support jQuery 1.6 */
	  if ($(this).attr("class"))
	    thisClass = $(this).attr("class").split(" ")[0];
	  thisClass = thisClass + settings.defaultClass;
	else
	  thisClass = settings.defaultClass;
	$(this).addClass(thisClass);
dynamo mailing list
It looks like they’re using a naive method of splitting the URL into its component parts. I would start by refactoring that part of the script. Look at window.location in MDN – there’s all sorts of bits in that object that are useful: window.location.pathname and .hostname and .search and .hash.
dynamo mailing list
