keywords / meta tags
GOod afternoon - I know that this has been touched upon, but if you can help w simple instructions I would be gratefully appreciative.
I have a few sited that need keywords and meta-tags to help in SEO and google.
How is this done in freeway? Thank you so much.
Julie
Here is a good link from Softpress:
It’s very easy to follow, open Freeway and your doc, make sure you are on the index page, select Meta Tags from the Page menu on top bar. Click NEW and add Keywords in Name field, Value would be your keywords typed one after another with just a comma separating. Click okay.
Then repeat the process, Name would now be Description and Value would be a well thought out description of your site’s business in sentence for.
For SEO - I’d look to see what your hosting company offers, submit to the major search engines or find a service that will do the submit for you…also check out the oldie but goodie Robots.txt. (http://www.squidoo.com/robotsengines)
Hope this helps.
Thank you so much.
I will try it and let you know.
so first name field: Keywords
and then keywords - do you put a space after the comma? I know in some things that makes a difference.
J
Search Engine Optimization and Meta Tags - Freeway - Softpress Talk
Hope this helps.
And if you haven’t done so already read Keith’s article at Be Found - design findable web sites that get ranked with the best
Apparently it is not necessary but just makes it more readable to you if you do.
A tip would be to visit sites that come highly ranked in the same fields as yours and have a look at theirs.
I would do my keywords in plain text editor and then copy/paste into the FW dialogue box.
But remember that keywords/metatags are not all they are cracked up to be.
Thank you,
That is what I thought I had read on the forum, but my client wants them there. It is better to be safe than sorry.
J
Yes but there are far more important things that will increase page rankings so make sure you do them as well. Read Keith’s article.
I am thank you so much.
J
Also remember that as of September of 2009, Google no longer uses keywords. Here’s a site I’d check out as well:
The Only SEO Tools You’ll Ever Need
and the article for proof Google doesn’t use them:
